front sway bar??
RE: front sway bar??
http://www.fordracingparts.com/download/enginetips.asp
you will the see the cam reports.... it comes up in adobe
ORIGINAL: lookinforastang
you could do better..
the ac delete was stupid i'd remove it because the ac is disabled at WOT anyway
not sure how much that cams worth with stock heads id say at most 10hp maybe more im not sure
you could remove the front sway bar not sure how much it would help you
obviously your launch is killing you 2.2 is nothing special.. i'd invest in some suspension upgrades like subframe connectors and U&L control arms
and those are some good times for what you have done.
I ran a 14.7 with everything done except heads, on street tires.
forgot to answer your question
yes, removing the front swaybar will improve your times a little, just because the swaybar limits how far the suspension can travel.
it increases weight transfer.
I did mine a couple of weeks ago and it is a night and day difference. but take it easy and get used to it before you get on it around corners and stuff.
