Wont stop trying to start
Every once in a while when I try to start my car the starter stays engaged after the engine starts. I have replaced the solenoid twice and it has a new starter and battery. Basically when it sticks there is no way to stop the starter unless you disconnect the battery cable or just wait about 15 seconds and it will stop on its on. I tried turning the key to the off position and even taking the key out of the car, but that has no affect. I am thinking my next step should be to replace the ignition switch..anyone have any input?
RE: Wont stop trying to start
ORIGINAL: 2 kwik
pull the starter and look at the brushes and armature
ORIGINAL: stanglx2002
have you checked the ignition switch in the steering column
The last time it happend I tried to pull the wire off the solenoid that connects the ignition switch to the solenoid..the starter kept going even with that wire disconnected.
ORIGINAL: MISTRDlCK
