So I installed a new AOD today, and now the car wont crank/turn over
Old 07-02-2006, 11:45 AM
  #21
OJMiles
OJMiles's Avatar
Default RE: So I installed a new AOD today, and now the car wont crank/turn over
I dont remember wether we did, or didnt... My cousin is the one heading this up and he's the one that has experience with this, plus he's owned about 5 or 6 foxbodies...
OJMiles is offline
Old 07-02-2006, 11:46 AM
  #22
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: OJMiles
Guess not enough in this case, sorry bro.
PRO50SC is offline
Old 07-02-2006, 12:16 PM
  #23
black88
black88's Avatar
well i hate to tell you this but advance kind of srcewed you. the torque converter for an aod and an aod-e are different. they are not interchangeable. there is a good chance you screwed up the front pump on the trans. you need to take it out and have it checked then go to advance and make them pay for the repairs. 93 mustangs didnt even get the aod-e so i dont know why they told you that. thats the reason you dont go to a place like that to buy important parts. when you bought the trans you should have gotten a converter at the same time then you would have gotten the right one
black88 is offline
Old 07-02-2006, 12:30 PM
  #24
OJMiles
OJMiles's Avatar
I've already said that I bought a TC for a 91 car with an AOD, not a car with an AODE. I bought a used transmission from Prestige Mustang parts, and i wasnt quite comfortable reusing the TC that came with it.
OJMiles is offline
Old 07-02-2006, 12:43 PM
  #25
black88
black88's Avatar
sorry i miss read it i was in a hurry. but you still need to get the tranny checked out cause if you didnt get the converter in all the way you could have still screwed up the pump and the converter. but you also got a used tranny so that could be the problem also maybe you got a bad one.
black88 is offline
Old 07-02-2006, 02:35 PM
  #26
hellas85stang
hellas85stang's Avatar
no diff in a aode and a aod od old except once is elect od and 1 is not all same inside n flywheel unless its goes from a 84 i think to a pre 84 then ounces are diff 1 is 50 oz newwer and 28 on older 302s...
hellas85stang is offline
Old 07-02-2006, 02:43 PM
  #27
angcobra
angcobra's Avatar
it is most likely the TC was not fully engaged into the trans. When this happens it push eveything back in the tranny and cause it to bind (thus not being able to turn.
The most critical check is the clearance between the TC and the flexplate when the tranny is fully bolted up. You should have 1/8 to 1/4 inch which will allow the TC to turn freely and slide up to the flex plate.
If you have not done so already, unbolt the TC from the flex plate and see if you can turn the TC.
angcobra is offline
Old 07-02-2006, 03:14 PM
  #28
OJMiles
OJMiles's Avatar
"no diff in a aode and a aod od old except once is elect od and 1 is not all same inside n flywheel unless its goes from a 84 i think to a pre 84 then ounces are diff 1 is 50 oz newwer and 28 on older 302s... "
engrish?
OJMiles is offline
Old 07-04-2006, 03:15 PM
  #29
angcobra
angcobra's Avatar
Well, did you find out what the problem was?
angcobra is offline
Old 07-04-2006, 03:39 PM
  #30
OJMiles
OJMiles's Avatar
havent messed with it... kinda disgusted and been working days so only 2 hrs of light when i get off of work.
OJMiles is offline
Quick Reply: So I installed a new AOD today, and now the car wont crank/turn over
