PLEASE HELP I HAVE A BIG PROBLEM
Old 07-02-2006, 02:30 PM
mustangfan90
mustangfan90's Avatar
Default PLEASE HELP I HAVE A BIG PROBLEM
I have a 90 5.0 mustang GT. I have a stock bottom end with AFR 185cc heads, E303 cam, BBK SSI intake with 1.6 roller rockers. Ok I was coming from the drag strip the other day and I pulled over to wait on a friend and when I did my gauge messed up and I think that m engine MAY or may not have ran hot. Well I sat there for a minute and then I cut my car off not knowing how long it would be before my friend got there. When I started it back it sounded like it was bogging out and when I drove it fuel smoke pours out of the exhaust pipe and it used 3 gallons of gas in 10 miles. I have changed the MAF sensor the MAP sensor the oxygen sensors the fuel presssure regulator the CTP sensor and the computer nothing is helping could I have ran it hot and cracked and head or intake or any of these gaskets. I have never seen an end run hot and drink this much fuel before. PLEASE HELP
mustangfan90 is offline
Old 07-02-2006, 02:33 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: PLEASE HELP I HAVE A BIG PROBLEM
what color is the smoke? white is steam, grey is fuel, blue is oil
rmodel65 is offline
Old 07-02-2006, 02:40 PM
mustangfan90
Seems white at idle not sure I know its grey when I rev it up and you can smell the fuel
Old 07-02-2006, 02:45 PM
92redlx
92redlx's Avatar
Could your fuel regulator be screwed up?
92redlx is offline
Old 07-02-2006, 02:46 PM
mustangfan90
Just put a new one on it
Old 07-02-2006, 02:52 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
maybe u have a frozen fuel injector? it could be dumping fuel
rmodel65 is offline
Old 07-02-2006, 02:53 PM
angcobra
angcobra's Avatar
Do you have a fuel pressure gauge, what is it reading?
angcobra is offline
Old 07-02-2006, 02:56 PM
mustangfan90
How can you tell if its hung open and answering the cobra questions I dont have one so I dont know
Old 07-02-2006, 03:01 PM
mustangfan90
Would cracked heads or intake or busted head gaskets or intake gasket cause this?
Old 07-02-2006, 03:03 PM
angcobra
angcobra's Avatar
ORIGINAL: mustangfan90
Good chance the new one is failed. Get you a gauge and see what the fuel pressure is.
When you crank the car, do you have to hold on the floor to crank? If so, this is a sign of fuel pressure too high. Holding on the floor during starting cuts the injectors off.
angcobra is offline
Quick Reply: PLEASE HELP I HAVE A BIG PROBLEM
