Tranny went kablow.
RE: Tranny went kablow.
Another option is a G-force tranny T-5 rebuild http://www.g-forcetransmissions.com/tran_gt-5.asp. This is my choice for doing it because it's just as strong as a tremec but you don't have to do any fancy things to it, doesn't putting in a tremec requires you to buy and modify things for it to fit in there, like tranny mount or bellhousing and stuff? Seems like alot of work (If that's true, I'm not positive, someone verify that?) for the same payoff. Besides, then you can say your just running a stock T-5, which would make people scratch their head.
+1 on the G-Force T-5 ........ apx $1,700
after that a "super alloy" T-5 rebuild. ........... apx. $900
www.astroperformance.com
other options
www.ddperformance.com
other options
oops, my bad. T-5. I was eatin it down the road and when i shifted into 3rd it was like KABAM KSCHDSHHSHSHSHSHSHHHHH. It wouldnt go into gear at all. Then i stopped and went and it went into gear i took it slow and it made grinding noises and i felt some very unhealthy things in the shifter. when i let the clutch out in neutral it grinds.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
