fuel lines and tank
fuel lines and tank
i just got my car back together and i found theres a leak around the gas tank. i dropped it down and clamped a few lines and it leaks worse now. so im sayin screw it and im going to do all new lines and gas tank. how do i go about getting the fuel pump out of the tank? is there a key to getting it out because i tried turning it and it dosent move and i dont see a clamp or anything? thanks gary
RE: fuel lines and tank
ya i filled it up and it leaked then when i drained it and dropped the tank didnt find anythin so i clampd some lines and it leaks worse so i wanna do the whole thing. how do i get the fillerneck out?
yup, could be the filler neck. but to get the pump out, there is a ring on top of the sending unit that has to be turned to ulock it, usually a hammer and a screw driver works pretty well. filler neck just slides out of the tank, there is a rubber seal where it goes into the tank that goes bad and leaks.
Matt's 95 Stang
10-05-2015 07:16 AM
mrappe
09-26-2015 10:16 AM
