gear oil
RE: gear oil
it is just above the large rib on the left side of the front housing, it could be covered up with crud, so poke around with a screwdrive and you will find it. use a 3/8 ratchet extension in the recessed square hole to take the plug out and be prepared to have some oil run out if it is too full. with the rear end level, the correct level is just up to the bottom of the fill hole, just be sure the rear end is level side to side when you check it.
RE: gear oil
ORIGINAL: vfast
get your butt under the rear and look*L*..it is a recess plug so a rachet can be used to pull it out..just look closer
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
