Help LOUD TICKING !
#31
RE: Help LOUD TICKING ! IMPORTANT 4 U !
Ok, through an engine machinist, if you are not able to physically push down the cup on your hydraulic roller lifter with your finger, then the bores are filled with gunk and carbon and should be disasembled and soaked in parts cleaner for 48 hours .
Once assembled you should now be able to move it up and down, no need to ever repalce the roller lifters.
This applies to all of you all of you that has roller lifters older than 60,000 miles.
The consequence is that YOUR VALVES DO NOT OPEN AND CLOSE AS THEY SHOULD AND YOUR SCREWED WITH POWER, rather or not you know it.
The alternative is kerosene being ran in the motor 4 quarts synthetic oil 5 w 30 , the rest kerosene.
#32
THE ENDING IS ALMOST NEAR
BEFORE AND AFTER PICS
[IMG]local://upfiles/23896/ECAE839F7D3C407B88423D4AFE249083.jpg[/IMG]
[IMG]local://upfiles/23896/FD08D37D022B4A849ED674A88CF666E8.jpg[/IMG]
[IMG]local://upfiles/23896/75747DD57089439780D4A2CE21FC810F.jpg[/IMG]
[IMG]local://upfiles/23896/61193DCBA9644F729EA009F6FA7323A0.jpg[/IMG]
[IMG]local://upfiles/23896/0AA9230996344C0AA5035529D92EF491.jpg[/IMG]
#33
Ok gang the lifters are in, the valves are adjusted and the timing set.
So far nice , quiet stable motor.
ONE UGLY ISSUE IM STARTING TO NOTICE, MY AOD MAY NOT BE HOLDING UP TO ALL THIS TORQUE, SOMETIMES IT REVS AND MAKES A NOISE LIKE A BELT SLIPPING ON A PULLEY, LIKE A POSSUM AND REVS UP. !!!! DAM , I JUST REPLACED IT A FEW MONTHS AGO!!!
BUT IF YOU FLOOR IT IT GOES/. ILL CHECK THE SHIFT LINKAGE, BUT I HIGHLY DOUBT IT, THOSE AOD'S STOCK SUCK
#35
RE: Help LOUD TICKING ! AND AOD ISSUE HELP
ON MY AOD ISSUE, DO YOU GUYS THINK THAT IT IS JUST MY TORQUE CONVERTER??????
IT MAKES THE NOISE AND RPM GOES UP ASAP ON LIGHT THROTTLE, BUT IF YOU FLOOR IT THE CAR WILL STILL FLY.
ITS LIKE DEAD STANDSTILL , ANY GEAR, TAP ACCELERATOR AND WENNNNNNNnNN!!!!!!!!!!!!!! NOISE VERY LOUDNA DN RPM JUST GOES UP.
FLOOR IT CAR WILL TAKE OFF, NOISE GET LOUDER AT TIMES DURING THIS THOUGH.
KingRando
10-02-2015 08:06 AM
