Help LOUD TICKING !
Old 07-03-2006, 12:34 AM
aode08
aode08's Avatar
Default Help LOUD TICKING !
ok my pony is ticking loud!
I got pissed, the shortblock is new and so are the heads .
I REMOVED THE VALVE COVERS AND THE NOISE WAS ALOT LOUDER(YEAH OIL EVERYWHERE, FROM RUNNING MOTOR).
Anyhow, I tightened all of my rocker arm bolts to see if the noise gets lower and nothing! NO EVIDENCE AT TOP OF WEAR ETC.
The only thing i did not replace during rebuild it the camshaft, camshaft bearings and the hydrolic roller lifters!! which im starting to suspect somewhat,
and i tightened all the nuts till they stopped and still the noise! I KNOW I KNOW, NOW I HAVE TO GOT THROUGH THE VALVE LASH ADJUSTMENT PROCEDURE AGAIN!
I was told to run the eninge till something gives and i dont want to do that, at all.
ANY HELP would be appreciated!
aode08 is offline
Old 07-03-2006, 12:36 AM
r.barn
r.barn's Avatar
Default RE: Help LOUD TICKING !
exhaust leak?
r.barn is offline
Old 07-03-2006, 12:39 AM
aode08
aode08's Avatar
I would not start tearing down my engine without cheaking for that lol, anyhow not that kind of noise it LOUD METALLIC, all bolts tight and all pieces WELDED, with NO FLAWS.
aode08 is offline
Old 07-03-2006, 12:41 AM
Scout2232
Scout2232's Avatar
Did it happen all the sudden, or has it done it ever since you put on the heads and stuff? Cause my RR's are noisy, my brothers chev 350 RR's are noisy and my gear guys' nova with chev 350 RR's are noisy also. So maybe it's those you are hearing.
Scout2232 is offline
Old 07-03-2006, 12:55 AM
aode08
aode08's Avatar
Well it was not loud 9 months ago, now its LOUD ! ! SUNDS LIKE A SKREW DRIVER TAPPING THE TOP OF ENGINE. I PUT A TOWEL OVER my roller lifters and pushed down on them still ticking. very loud. Car drives awesome, starts asap , power ok, could be better.
aode08 is offline
Old 07-03-2006, 01:01 AM
Stevens91gt
Stevens91gt's Avatar
header gaskets??
Stevens91gt is offline
Old 07-03-2006, 01:05 AM
aode08
aode08's Avatar
no , I checked all them and all bolts are tight,
I know exhaust from metal hitting metal.
aode08 is offline
Old 07-03-2006, 03:01 AM
adam5litre
adam5litre's Avatar
You said new heads and new short block?!?!
Are you sure the Piston to Valve clearance is OK?!?!?!
adam5litre is offline
Old 07-03-2006, 03:12 AM
steele901
steele901's Avatar
my 95 5.0 does the same thing after putting on new gt-40p heads. its slowly gotten louder. still don't know what it is. a local shop said its just rocker arm clatter. some are just loud. well it annoys the crap out of me. makes my motor sound ratty. let me know if you figure it out
steele901 is offline
Old 07-03-2006, 03:15 AM
Stevens91gt
so when does it do the ticking? at idle? accelerating? steady speed? revving up?
Quick Reply: Help LOUD TICKING !
