wheels and tires
wheels and tires
i have a 89 notch that is lowered about 2 inches. i want to put fattys and skinnys on. any1 know the biggest i can fit on the rear with the correct backspacing and bolt diameter?
thanks gary
thanks gary
RE: wheels and tires
Try calling summit tech support, they should be able to tell you what you'll be able to fit.. the 2" lowering is whats mostly going to hurt you. Also I believe the 87-89 had a wider lip on the underside of the wheelwell, so you may have to trim that. Give them, or even Weld Wheel company a call... they'll be more than happy to help you out
09-08-2015 11:50 AM
