76mlairmeter with 70ml throttle body
I just bought an 87 mustang with mass air conversion and a 70 ml throttle body and the stock mass air flow from a newer mustang. I am on a tight budget and found a 76ml air meter. Will that work with a 70ml tb? also do air meters come with a different sensor or do You ues the stock sensor. I will be using this with stock injectors.
RE: 76mlairmeter with 70ml throttle body
76 would be perfect for a 70 mm tb. your mass air meter will need to be calibrated to match your injectors. if they're stock youll need a maf calibrated for 19# injectors.
