Need advice on low oil pressure
Old 07-05-2006, 04:18 AM
  #21
Twisted
Twisted's Avatar
Default RE: Need advice on low oil pressure
ORIGINAL: titanium92
The pressure actually dropped down to the Low line on the stock gauge when it was idleing like it was missing. Then goes back up when driving.
Just to be clear, you mean the lowest line--as in the first line from the bottom? For reference, my needle at its lowest (at idle), reaches a hair below the halfway line. At it's highest point (say, on the highway), it reaches a hair below the next line up from the halfway line. Not to jack, but does that sound like normal pressure?
One comment about your car, Titanium: If the car was missing, and the idle dropped, wouldn't that cause a drop in oil pressure?
Twisted is offline
Old 07-05-2006, 04:28 AM
  #22
primetime5.0
primetime5.0's Avatar
like they said dont pay attention to the stock gauge, mine always read zero before I got an auto meter one
primetime5.0 is offline
Old 07-05-2006, 04:51 AM
  #23
titanium92
titanium92's Avatar
Well my needle at idle was just above the half way and running was just a hair under the line above the half ( roughly 3/4 line). That is what I was asking about the timing having anything to do with oil pressure because when it was missing and RPM's went down alittle that's when the pressure drop to the Low line.
titanium92 is offline
Old 07-05-2006, 04:56 AM
  #24
titanium92
titanium92's Avatar
Also after this happening I will definately get some aftermarket oil pressure gauge. I will make a seperate post to see how difficult it is to install and which gauges are better and what should the pressures be normally. Like what grabbem said " cold start up i run 55-60 psi after warm up it drops down to 45-50,and when i run the bejeebish out of it it has dropped to 35psi at idle which is fine...you need for every 1000rpm 10psi of oil pressure. "
Old 07-05-2006, 05:21 AM
  #25
lookinforastang
I ♥ Acer
lookinforastang's Avatar
ive had my gauge drop to the L and my cars not missing or anything and dosnt burn any oil
it went back up but and it still "operates" or works if u wanna say that but i dont feel it is accurate but it moves.. so theres got to be some kind of pressure.
ive had problems with all the gauges except for the tach.
speedo bounces
gas gauge is off
volt gauge ticks sometimes (batt is fully charged and alt is new)
temp gauge is off
gotta love the ford instrument cluster
lookinforastang is offline
Old 07-05-2006, 02:38 PM
  #26
hellas85stang
hellas85stang's Avatar
AFTER YA MOTOR WARMS UP AND OIL PRESSURE DROPS THEN..PROB ya cam beraing are worn..... come on guys this is basic motorology..lol90% of time if ya oil pressure drops after warms up and i mean bottoms out,its goonna be ya cam bearing...
hellas85stang is offline
Old 07-05-2006, 03:05 PM
  #27
3stangs
3stangs's Avatar
If RPM drops than your oil pressure will drop too because your cam is turning slower. You said it started scipping and the RPM went down, so wouldn't that be normal for oil pressure to go down. Don't worry about the pressure till you fix the scip , and then recheck pressure. just my 2cent
3stangs is offline
Old 07-05-2006, 06:34 PM
  #28
grabbem88
grabbem88's Avatar
no it does not..don't sell b.s. if you're not 100% sure what's going on...
like i said before ford clearance is loose..so when the oil warms up...what happens???the oil stretches i.e. viscosity....his bottem end is fine.
ORIGINAL: hellas85stang
grabbem88 is offline
Old 07-05-2006, 10:32 PM
  #29
titanium92
titanium92's Avatar
I appreciate all your feedback guys....so I decided I will get new spark plugs (I will just get motorcraft ones) clean out the distributor cap and re-adjust the timing. I will eventually get some good aftermarket oil pressure guage. Then I can see from there, what's going on. If that doesn't do it I may just a mild cam and then change out the bearing in process. Take it one step at a time. I don't really want to put a cam in with stock heads and intake but would it matter if I did. Eventually I will get heads and intake just not this year.
Omgitsa88Stang
10-05-2015 07:33 AM
dalefrancis88
09-11-2015 07:15 AM
Pyrate Dave
09-10-2015 07:30 PM
kevsgt
09-09-2015 06:20 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Need advice on low oil pressure
