looking for some help building another motor
#24
RE: looking for some help building another motor
come on shifter.....since you're the only one that knows a little bit......
just curious...is a 460 more expensive to build up vs. a 400?
#25
ohhhhhhhhhhh sorry, umm let's see here. No they will be about the same in theory. You can however build a 460 and make 450hp with a bone stock C8-C9-D0VE head. If you running a truck with large tires and so forth, gonna hard to beat a big block for grunt.
#26
as far as the small 600 using a stub stack will give you another 20 cfm's and changing the linkage cam to a faster rate will help with that low end grunt.. throttle response will be good...also milling the horn will help as well
#27
Re Cam: Comp extreme flat hydraulic 262 cam 218 224 @.050 with .513/.520 lift on a 110 lobe sep. This is a 120 dollar cam through summit and it will pull like a beast from idle to 5500 in that 400 inch motor.
#28
thanks alot guy's...i think what's all said this 400 will make this 5000lb beast move pretty good...
gas mpg already sucks in this thing so maybe with a better performing,and breathing engine it might be better?
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
logan409
09-26-2015 07:43 PM
