Intakes
Intakes
What does everyone think is the best lower and upper intake manifold combo? Also what kind of power do they gain and how much horsepower can they handle, both ported and not ported?And how much do they cost?
RE: Intakes
Trick Flow street heat for mildly modded 5.0's. Can be had for around 300 bucks used or around 400 new. I'm not exactly sure on the power gains that I got though. What are you trying to decide on and what are your mods???
RE: Intakes
heres the list
1. BBK 75MM THROTTLE BODY
2. BBK 75MM EGR PLATE
3. BBK Shorty Headers
4. BBK Off road H-pipe with no cats
5. BBK FUEL PUMP 255 LITERS/HOUR
6. Ford racing 30 lb injectors
7. BBK SSI Intake (honed out)
8. Ford Racing Aluminum Driveshaft
9. A/C eliminator
10. Smog pump eliminator
11. Ford Racing 3.90 gears
12. MSD 6Al Ignition Kit
13. MSD Blaster 2 Coil
14. MSD 8.5 MM wires
15. NGK spark plugs
16. MSD Distributor
17. King Cobra clutch
18. Rebuilt t-5 tranny world class
19. Pro 5.0 shifter
20. Steeda clutch cable
21. Hypereutectic Flat Top .30 pistons
22. lunati camshaft with Duration 284/292, Lift .500/.510
23. Hi flo oil pump
24. BBK Cold Air Intake
Block is bored .30 over and has stock crank
Heads are also ported, buit stock
This is what i haev but im debating on the BBK SSI, im still leary on if it is as good as the magazines make it sound. Also im eventually getting AFR heads and a Novi 2000. on a DSS 331 block
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
