throwing away money
throwing away money
I've got a 95 gt and I was having a idle problem, ford said my ecu and wiring harness needed to be replaced (2grand). Took it to a performance shop replaced egr, iac, and maf. Decided to take it home after throwing away money and still having the problem. Ran the KOEO and KOER codes 51 and 117. ect sensor. noticed the resevoir was low added half a gallon of distilled water ($0.50) had to drive down to the auto parts store to pick up the ect. Started the car light was out the car was idiling like it should. F*CK. Lesson learned! Make sure you check all of your fluid levels. It could save you a couple hundred bucks........
RE: throwing away money
Guess you missed my post from your other thread huh?
Sorry you had to learn the hard way!!!
Take that shyt back and demand a refund, Christ, they didn't fix it!!!
ORIGINAL: PRO50SC
You need to check the ect for the proper voltage at dif coolant temps. More than likely that's whats wrong.
quote:
ORIGINAL: PRO50SC
Well I did check the ect voltage and i couldn't c a large jump in #'s. everything was about were the book said it was supposed to be. But there was a wear spot on it from where the coolant was coming across it. so i just figured that was mayb the prob. ended up not. fortunately that was one part that I did not uselessly purchase. well now atleast i can get back to drinking more again.
ORIGINAL: PRO50SC
ORIGINAL: 95w.i.p
oh by the way thanks for the help. I was quite frustrated at the time and bout to put it away and start driving the truck again
well you have to learn some how. atleast it ws something simple. did some preventative maintance, a little upgrade, lesson learned, and it feels like i am driving a new car. (not really but you know what i mean).
