My car's gonna shake itself to pieces!
RE: My car's gonna shake itself to pieces!
lookinforastang :those are rigid chasis bikes ... softtails are comfortable... ur car needs foose and overhaulin by the sounds of it...j/k anyhow rixter check all your plugs & wires, distributer cap/rotor, check timing, harmonic balancer, maf wires, base idle, IAC, TB, fluids, check headers for a leak... good luck.
if you're gonna replace the clutch then yes, replace (or resurface) the flywheel. check the harmonic balancer for wobbling with the car running. also, with engine off of course, inspect the thin ring of rubber that holds the inner and outer hub of the balancer together.
if you see that it is dry and cracked you should replace it. if it is very old, replace it. $67 from Dallas Mustang.
Ok... I really don't know what I'm talking about here and I'm sure you guys will laugh at this...
But my car did the same basic thing. I have 01 GT and at first I thought it was related to a particular RPM. I have an automatic so it was hard to pin it down but later I found it was due to being above a certain speed.
Anytime I went above about 40 my car would shake like mad. It was so bad I had to get off the expressway.
I took it into a shop that I use and I know the mechanics really well and what he found after just about 15 minutes of looking was a huge clump of dried mud had settled in my right rear wheel on the inner side and was putting it horribly out of balance.
He asked how I got mud in there but thats another story. Let's just say that a heavy rain during a soccer game and you'll find out how your stang handles in the mud. Mine didn't do so well.
I thought I had hosed off all the mud at the car wash but I guess I missed some. I drove the next 3 or 4 days never reaching that speed as I had short little in town errands. But when I finally did reach it wow what a shake!
Jen
Jen
ORIGINAL: lookinforastang
could be the tires, driveshaft, number of other things
my car shakes but its from a combination of things.. the driveshaft looks older than me, the brakes are worn to bare metal, and the tires are heavily worn.
u would think my car would be like riding a soft tail bike or whatever those bikes are called with no suspensions.
oh yah not to mention my shocks and struts are shot and the tie rods are wearing!
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
