Bucking and idling high
My car just statring idling at 1500 the other day and a week later now it idles at almost 2500 and it bucks in like 2nd gear when i have it at 2000rpms just cfruising down the street any ideas as to whats wriong with it??
RE: Bucking and idling high
Idle high + bucking....check for vacuum leaks, disconnected vacuum lines or hose (PCV, vacuum tree, brake booster check valve, etc)....or you may have a problem with the TPS, stuck IAC valve,....check TPS output voltage, or run a DIY KOEO/KOER self-test to check for any other failure codes that may be causing the problem.
Matt's 95 Stang
10-05-2015 07:16 AM
