Bad Strut?
RE: Bad Strut?
definately ball joint i replaced my struts cause thats what the mechanic thought it was the squeekin went away for a day then it came back and i had to tear apart the whole front end again to replace the ball joint and whats good about that the aftermarket ones come with greaser so you dont have to worry about them going out again. and i did one and the other one started squeeking so just do both sides
RE: Bad Strut?
everything up front is greased. it is very easy to steer. this noise will go away and come back alot. the only reason i want it fixed is because it is seriously one of the most annoying things in the world! if i push down on the front end it does it too. so turning, and up down motions cause the noise.
RE: Bad Strut?
i get like a clicking and tapping noise when i turn left
and the sharper the turn, the louder it gets.
i was told tie rods but its not in the front its in the rear right by the quarter panel on the passenger side
i was thinking maybe its the filler neck bouncing around? but why only on left turns?
oh ya if i slow down it will only click like once but if im goin the speed limit its constant
