NEW HP & torque Specs
#22
RE: NEW HP & torque Specs
ORIGINAL: myshifter
air fuel ratio? Just wondering what its at around peak levels
#23
jay made the cam... .550/.533 229/239 at 112....dyno guy shut me down at 6k though
said there isn't anything after 6000 anyways.
ORIGINAL: myshifter
stock afr head? If so, send em to me, 50+hp right off the bat, ya vic jr is a top end chrger, all single planes are. Your combo is way off somewhere. Just cause there an aftermarket dont mean nothing. "It aint a bolt-on, till its modified"
#24
ORIGINAL: BascoSauce
damn man, nice effin set up!!!!!!
specs on it look really nice, watcha runnin at the track??
#25
ORIGINAL: myshifter
Heads aren't afr's they are made by ProComp
#26
im not doubting the cam, jay is great. One point compression will yield another 10 or so hp, ported heads is another 40-50+. Is the cam stright up, did jay do the cam dr service, did you degree it? Bunch of things going on.
#28
ORIGINAL: Crump_4
ORIGINAL: myshifter
#29
i question this also....my helper (which is very good) put the cam in...he zeroed it at tdc.
which is what jay said to do,and yes my cam is dr.ed...how much of a loss is degreeing?
btw...with old cam 512/512 224/230 at 112...i made exactly the same numbers
ORIGINAL: myshifter
#30
well degreeing is just a double check of what the stated valve events are, not uncommon to get a cam a few degrees off. Now with jays cam I can say thats not gonna be a problem. His are extremely close, dead on. I would play with some advance and see what happens. Your injected right?
