dss long block
#33
RE: dss long block
ORIGINAL: FiveLiterRiceEater
so instead of putting new rings in you bought a whole new engine. good call!
#34
RE: dss long block
ORIGINAL: Bad Karma
Were they the ProX Pistons??
What options would you rec if you were building again?
Thanks,
Ivan
Thanks,
Ivan
#35
RE: dss long block
Both blocks and setups were AFU then huh?? Sorry to hear. You must beat the ever living schitt out of them yes??
I haven't heard too many stories like that before..Is DSS going to help you out in any way since it was their setup that (?)failed??
Or was it entirely your fault? I would like to think that a big company with their name on the line would want to help you out.
-Ivan
-Ivan
#36
RE: dss long block
ORIGINAL: Bad Karma
-Ivan
-Ivan
#37
RE: dss long block
ORIGINAL: BCP
Didnt have much choice. When the rod broke ( about two inches dont from the pin) the piston rotated in the bore thus mis-aligning the valve reliefs which in turn caused a PTV issue , which mangles the piston enough to break the head of the valve off and embed it into the cylinder head while the remaining pieces of the rod destroyed the cylinder wall thus destroying the block.
not you, i'd be replacing the engine if i blew it up too.
#38
RE: dss long block
ORIGINAL: BCP
treesloth
09-28-2015 07:03 AM
