Where to pour in seafoam? ... w/ pics
RE: Where to pour in seafoam? ... w/ pics
Is there danger of fouling the plugs? I have a hard start problem that I am attributing to carbon on the valves, but I have just changed the plugs and do not want to foul them.
ORIGINAL: dryvingnut
Best way throught the PCV line, let it suck enough to kill the car and let it sit overnight. Am I correct in this?
ive never had to change the plugs either but my plugs were brand new pvc line i just open the can wipe off the out side of the booster line till it sucks 1/3 to half of it in let it stall the engine then pour the rest in the tank clean just like the direction say the inside of my car out then start it and watch the smoke show. as for the port that pictured it doesnt pull stong vaccum
ORIGINAL: primetime5.0
the pcv is under the intake which is hard to get to for most just use the brake booster line, you would use the pcv on a mod motor
It's got the directions on the can...use the brake booster line. You want something that feeds all cylinders equally. It may be helpful to have one person pouring and one person on the gas to make sure it doesn't die. Be sure you are somewhere where the people won't call the fire dept b/c of all the smoke.
