What size TB and MAF?
RE: What size TB and MAF?
has anyone herd of "gutting" the stock maf?? on the stock one there is a good size piece of metel that runs down the middle that has NO use, ive looked. i though i herd someone say you ca cut that out for gains but i duno how or if you can
ORIGINAL: 5.0 MPG
I think I'll go with 92hatche's set up. 70 and 75.
There are several reasons you want to avoid too big of a TB.
1--like they said, the intake will cause interference if the opening is not as big as the TB.
2--you can lose air velocity if the TB is too big
3--The MAF needs to be at LEAST the same size as the TB, but a larger MAF helps keep air velocity up. If the TB is bigger [like the stock setup], the MAF becomes the restriction.
It's a great set up, I didn't lose any bottom end torque and I felt a gain in the upper rpms, this was with the stock intake. When I add the TF manifold, with a CAI, MAF, and a TB/EGR spacer the gains were just wild. I paid about 180 bucks total for my 70mm BBK TB, 70mm BBK EGR spacer, and my 75mm Pro-M MAF. Damn do I love e-bay, there wasn't one thing wrong with any of it either.
