What you guys think?
I was jsut wondering what kind of HP i should expect from my setup heres my list of mods. 91 gt still 302,AFR 185cc heads, trick flow track heat intake, speed pro engine rebuild kit 10.13:1 compression i think, 65mm TB, hooker comp headers, x pipe, FR drveshaft, moroso in fender intake, 255lph fuel pump, granatelli dist., be cool radiator, elec. fan, underdrive pullies, smog ele., 140 amp alt.XE274-hr comp cam fuel reg.. I saw the articles on the AFR website on how they got 400 hp with the 185 head on a 302 but i just wnat to hear from you guys out there if you have any experience with this kind of set up and what did you get from the dyno.
RE: What you guys think?
I'm not sure I can answer the question, but I have another question for you... what size injectors are you running and what are your cam specs?
I don't believe you'll hit 400 hp normally aspirated at the flywheel, and definitely not 400 rwhp with your set up. |
24lbs injectors.
cam specs: ADV dur. intake-274, exhaust-282. gross valve lift- intake-.555, exhaust-.565 intake centerline @ 108.0
