Installing headers
Old 07-10-2006, 08:44 PM
Keeler
Keeler's Avatar
Default RE: Installing headers
I installed on the ground, but it is difficult and a lift ot even floor jacks will save your back and your mental health
Keeler is offline
Old 07-10-2006, 08:48 PM
93foxgt
93foxgt's Avatar
So the general consensus it to wait until I can lift the car a few inches higher?
93foxgt is offline
Old 07-10-2006, 09:36 PM
mustang93
mustang93's Avatar
yupp yupp get some jack stands! makes it alot easier! you will prolly need longer extensions too. you might need ot remove some of the smog pump hoses, and the plugs and wires should come off too. just make sure you know which wire goes to which cylinder.
mustang93 is offline
Old 07-11-2006, 01:14 AM
93foxgt
93foxgt's Avatar
Another Q:
The exhaust studs that are attached to the "fire cone" section of the headers that bolts to the H-pipe, where do I get them? Can I just use the ones already on my stock headers? They are BBK 1 5/8 unequals... and I think they're ceramic .
Thanks all!
93foxgt is offline
Old 07-11-2006, 03:03 AM
93foxgt
93foxgt's Avatar
Anyone?
93foxgt is offline
Old 07-11-2006, 03:15 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ORIGINAL: 93foxgt
Well, I shelled out $40 extra for Stage 8 locking header bolts. I hope they're long enough... they're only 3/8" in full (counting the head) but they look good. They're supposed to never come back out until you want them out.
Thanks for the quick answer. Any other tips?
did u shell out the extra cash for some dead soft gaskets well worth the money!
rmodel65 is offline
Old 07-11-2006, 04:43 AM
93foxgt
93foxgt's Avatar
I got some felpro performance gaskets. They're a pretty close match (closer than the BBK) and they're supposed to be metallic laminate and everyone told me to get them. Are there better worth sending these back for?
Also, the exhaust studs that are attached to the section of the headers that bolts to the H-pipe, where do I get them? Can I just use the ones already on my stock headers? They are BBK 1 5/8 unequals.
93foxgt is offline
Old 07-11-2006, 09:58 AM
7upedition
7upedition's Avatar
use the fel pro gaskets and dont us the cork/paper ones bbk supplied.. also torques specs are min 40 ft lbs ... just double box two openended wrenches to gether and tighten the sh*t out of them and revisit them every few weeks for a couple months just to make sure they dont loosen due to vibration... those stage 8's work sweet though
7upedition is offline
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Installing headers
