Smoke Screen
Smoke Screen
Got a problem guys (and gals) and hope someone can help! Anyways, Im getting a really noticable grayish smoke outta the back of the mustang when Im on the gas after 80+mph. It looks like its coming from the engine since it's dispersion (the whole rear end) and not specifically the exaust (at least i think not, I know I know...how can I tell where its from blah blah blah). My guess is a oil leak ? I have a novi 2000, but dont really think thats the prob! A gasket ? HELP, Im really baffled!
[&o]
[&o]
RE: Smoke Screen
It will only overheat if the part of the head gasket that is blown is near a water passage.....I blew mine between cylinders 2-3 so it was blowing in between those 2 cylinders.....(too much spray blew her).....opps.
RE: Smoke Screen
Check the back of the motor where the lower intake meets the block (end rail). If you see oil puddling or dripping back there it's either a loosely fitted PVC valve or oil leaking from the rear lower intake gasket at the engines end rail. Also, check valve cover gaskets.
How do you have the tube from the valve cover routed? is it hooked up into the inlet tube or vented into the atmosphere?
If you have excessive blow by, and you have the motor venteding back into the inlet tube of the blower it'll end up out the exhaust as bluish smoke.
Do you see this smoke mainly under boost?
RE: Smoke Screen
You probably have an oil leak....check the valve covers....they are know to leak down the backside of the motor. I dont think you are getting too lean at WOT. Look under your car and see if there is any sludge build up on the back side of the motor...on even on the motor itself. That will be the tell tale indicator it you are leaking oil.
Remember it your Mustang isn't leaking then there is something wrong .....keep me update.....
Easton
Easton
