AOD WHINE/grind AND RPM GOES UP
When flooring the car, the AOD will make a noise as if a serpentine belt squeal/grind, then rev up without producing output.
Does this sound like the torque converter? or tranny
Im NOT putting another AOD in unless its bullit proof, this is my second one !!
Ill check to see if it does it in any gear or just OD tomm[:@]
RE: AOD WHINE/grind AND RPM GOES UP
Have you tried playing around with the throttle valve or is it shifting normally? It could be the pump is whining but thats just a guess. I would personally take it to a trusted tranny shop if it were me.
Omgitsa88Stang
10-05-2015 07:33 AM
