speed density to MAF
05-14-2004, 12:04 AM
What are some of the better companies that sell conversion kits to change from speed density to mass air flow?Any one better than the rest?
05-14-2004, 12:10 AM
RE: speed density to MAF
if you have an auto i can help i even bought a $230.00 wiring harness i couldn't use i took two plugins off..... mass/coil plugs i have the mass air too you can have all of it for $125.00
05-14-2004, 12:22 AM
No I have a 5 speed
05-14-2004, 12:29 AM
i thought i'd try...i had it in my car for a year didn't have any problems...just got sick of the check engine light coming on.
05-14-2004, 12:35 AM
Mine is in process bought a 86 5.0 5 speed just seeing what I need to do to up grade, looking at AFR heads also. Just starting out trying to get info to swap into a 68 coupe. Have a lot to learn
05-14-2004, 12:41 AM
get the afr's can't go wrong there the wiring harness i told you abou is for your king of swap...i wanted a better one,found out fuel pump relay is tied in under my seat,and didn't want to do any more spicing.
05-14-2004, 12:53 AM
Hey grabbem, what all do you have for a conversion? I have an auto and I am looking to go to mass air soon.
05-14-2004, 01:00 AM
i have an a9p computer, the mass air, t -body i have two wiring harnesses one spd/density and one aftermarket butchered,but i can get you one whole/complete whatever you need i can get don't have the inlet tube though...walked off go figure huh.i'll tell you what throw a price and it's yours.sound good?
05-14-2004, 08:16 AM
Let me ask you a few questions first. Have you done your conversion? If so how hard was it to wire up? And would you take 75 for the just the comp, and the meter?
05-14-2004, 08:31 AM
I would like to get in line behind fantasyfords if he passes. Let me know
