C&L MAF question
07-11-2006, 07:56 PM
C&L MAF question
I recently bought a used 76mm C&L MAF with a 24lb calibration tube. I'm currently running 19lb injectors and my question is, would it be safe to run the 24lb MAF with my stock 19lb injectors?
07-11-2006, 07:59 PM
RE: C&L MAF question
why did you buy the MAF with the 24lbs tune? if you are pushing over 300hp just make sure your next mod is some 24lbs injectors
07-11-2006, 08:27 PM
It was used and at a good price... I'm pretty much all stock right now.
07-11-2006, 08:31 PM
ill trade you a 73mm C&L calibrated for 19s if you want to trade?
07-11-2006, 09:14 PM
Do not use meter calibrated for 24's with your 19's
just buy a new 19# sample tube for the meter, good thing about C&L meters is
the easy to change them over.
07-11-2006, 09:24 PM
Quote:
ORIGINAL: r.barn
Cool, I already ordered a 19# tube... I'll just hang on to the 24# tube when I do decide to upgrade.
07-11-2006, 10:26 PM
The Rogue Mod
Quote:
ORIGINAL: r.barn
+1 for sure!!
07-12-2006, 12:59 PM
No doubt. It's not worth keeping a 24 lb. tube in the MAF with 19 lb. injectors.
The tubes are cheap and sim ple to install.
07-12-2006, 02:09 PM
I ♥ Acer
make sure you get the tube for the 76mm and not the 73mm as thay are different just look at the color stripe that it has
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
