just installed tfs top half lots of problems
RE: just installed tfs top half lots of problems
ORIGINAL: 94BlackCobra
it seems to run pretty good past about 1500 rpms so i wouldnt think its the timing
Put the timing light on it and see what you get.
This is the most common mistake to make in this type of procedure so it needs to be ruled out first.
I can't tell you how many times I have screwed the dist up, and thought it was set perfect.
After that pull the codes, it may provide something useful.
jason
