just installed tfs top half lots of problems
Hey everyone, like the title says i just got done installing the tfs kit on my 94 cobra. I have a couple of problems. First the car wont even try to idle, i have some backfiring coming out of the trottle body, and my car is dumbing so much extra fuel out the tail pipe that my cats were glowing red hot. I know i need a tune but im almost scared to drive it someplace
RE: just installed tfs top half lots of problems
[>:]DAM ANOTHER VICTIM
your upper and lower intake manifold has a very specific and touchy procedure for the torque/bolt pattern. if not follwed to a tee, you will develop an intake leak rather or not you know it.
In your case unmetered air is entering your engine and is unacceptable.
What injectors are you running? Do you have a fuel pump large enough to supply it with enough fuel? Like the others said, timing, firing order, and vacum leaks might also be a problem.
