vacume tree and wire removal
Old 07-12-2006, 11:22 PM
HACKGT350
HACKGT350's Avatar
Default vacume tree and wire removal
ok so basicly all my vacume trees have been plugged off on my fire wall there were all emmisions stuff for the smog pump egr carcoal boxes and such, keep this in mind im running a carbed app. basicly all i have running for vacume liines are the brake booster and the vacume advance to the distributor. now my question is can i just take the trees off and the wires and where do the wires run to, they go into the fender and thats as far as i know.
HACKGT350 is offline
Old 07-12-2006, 11:30 PM
Crump_4
Crump_4's Avatar
Default RE: vacume tree and wire removal
one of them runs your heater/AC duct position
Crump_4 is offline
Old 07-12-2006, 11:33 PM
HACKGT350
HACKGT350's Avatar
thats ok thats all disconected already haha my heat runs fine and my ac is disconected
Old 07-12-2006, 11:34 PM
Crump_4
Crump_4's Avatar
true but the heater flap that controls when it is in defrost, vent or floor is run off of a vac. line. Im going through the same thing right now so if I need any advise can I PM you?
Crump_4 is offline
Old 07-12-2006, 11:37 PM
HACKGT350
HACKGT350's Avatar
my car only has the three different controls defrost heat and ac the defrost and the heat are switched by a door that blocks off the different vents from floor to the top of the dash
Old 07-12-2006, 11:39 PM
Crump_4
Crump_4's Avatar
PM me and let me know how it comes out. Any help or info is greatly appreciated.
Crump_4 is offline
Old 07-12-2006, 11:41 PM
HACKGT350
HACKGT350's Avatar
ok cool sounds good but my main question is still out there can i just take the trees off and the wires. my boss said it should be fine since everything has been blocked off anyway
Old 07-12-2006, 11:44 PM
Crump_4
Crump_4's Avatar
give it a shot and see what happens. my guess is that its going to a vacum can. but I could be wrong
Crump_4 is offline
Old 07-12-2006, 11:46 PM
HACKGT350
HACKGT350's Avatar
i would have to take my fender off to get to that right?
Old 07-12-2006, 11:52 PM
Crump_4
Crump_4's Avatar
dont quote me on this but I think so. and you need that can so you can make sure you have 14lbs of vac. so your power brakes will work.
Crump_4 is offline
Quick Reply: vacume tree and wire removal
