Is a short shifter worth it?
I tried a short shifter once on the first stang I drove when I was 17 it had 3:73's as well.. anyhow I never ripped his stang he had the stearing wheel tilted max to the bottom.... Anyhow I am very happy with my stock shifter can any of you change my mine??
RE: Is a short shifter worth it?
Youre in Europe arent you? Cant you change it yourself? But, to answer your question yes a short shifter is worth it. Itll help you shift faster, and most short shifters also have shift stops which will prevent you from over extending your shifts (when racing) and causing damage to the trans.
-P.
-P.
ORIGINAL: P Zero
-P.
-P.
I don't know what he means either, but I second the motion about the shift stops and the vbalue of having them.
Def well worth it.
-Ivan
