wtf
RE: wtf
i reused the olf ones cause they were basically bran new they were in such good shape.... i cut the ones off the slide onto the coil like a tube and wrapped them around the new one.... they were in really good shape....and if i really want to i can just put new ones on in like an hour....
RE: wtf
thats the same height mine is.
I think your dads friend is right, that is if you dont correct your suspension soon.
Your going to need new CC plates, bump and steer kit and maybe control arms to correct your alaignment and tie rods. If you look at your tie rods now you can see that they are bowed where as with factory spring they are straight. You should probaly look at investing in some better struts and shocks so your not bottoming out. When this is done your alaignment will be correct and your suspension will last a lot longer. If you dont correct these things you'll wear out your tires, tie rods, rack, bearings etc, etc....... a lot quicker.
Just remember with every upgrade comes another.
RE: wtf
my shocks and struts actually arent that bad and i havnt bottomed out yet but im gonna replace them soon ........ im hopin to make this baby handle like a roadrace car
RE: wtf
I think it sits a little to low in the front. If you ever want to go with bigger rims you will have a hard time fitting them. I like the even look myself! How come the Eibach springs are so popular? I thought they were more of a touring spring? Not the best for performance
RE: wtf
they are pretty damn good in my opinion and the car handles way better ......... and the front is alittle low but i might go with coilovers on the back and even them out...... im goin with 17x9 bullits up front and 17x10.5 bullits out back.... and i know ur gonna say they wont fit ...but ill make them fit
