very dissapointed PLEASE HELP
RE: very dissapointed PLEASE HELP
ORIGINAL: myshifter
Im not sure what you are trying to accomplish. Just cause it has the old firing is no big deal. I wonder if its a roller block though, even though its more than likely just has a flat tappet hydraulic cam.
ORIGINAL: kevinek
Is that what Ill need for this engine a solid roller cam?What about heads are the heads advertised for the 5.0 h.o work alright on
ORIGINAL: myshifter
so what, run a solid roller cam, makes more power than the hydraulic roller cams, no big deal whatsoever. HO-schmo, nonsense
ORIGINAL: kevinek
This isnt even a 86 mustang h.o this has the firing order out of a non roller 302 like a truck or a crown vic.What can I do?
ORIGINAL: kevinek
I was just about to order the trickflow head cam and Intake for my car and now Im wondering will that work even if I dont have the roller block?if it will what firing order would I use then?
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
the heads and intake will work fine, the cam wont. Since the firing order is different I can all but guarantee its just a standard hydraulic flat tappet cam. So either order the heads and intake, then order a hydraulic cam from comp, crane etc... On the other hand if it is a roller block but using a hydraulic flat tappet cam, you could order the roller lifters, hold down and links and then use the TFS cam. Go take the the uppr and lower intakes off since your buying an intake and see if atleast its a roller block, or find a casting number. If it is a roller block just using a hydraulic cam you can use the TFS cam provided you buy the hold down, lifters, links. You really need to find out if its a roller block or not, thats first.
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
You always find a way to brighten everyone's day up!
Thanks for the smile Sir,
Ivan
thats the kind of people i like on this forum that can always have good stuff to say instead of the usual " yea.... ur f*ked'
ORIGINAL: Bad Karma
Ivan
ORIGINAL: myshifter
ORIGINAL: kevinek
Ivan
ORIGINAL: 91lxstang
ORIGINAL: Bad Karma
Ivan
ORIGINAL: myshifter
ORIGINAL: kevinek
Ivan
ORIGINAL: kevinek
Im sure this is a stupid question but how can I tell when I get the intake off if its a roller block?Thanks,Kevin
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
let me know if you see two holes directly in the center of the lifter valley that are drilled and tapped. Those would be for the lifter hold down. If there are no holes directly in the center of the lifter valley it's a standard block, but Like I said, its no big deal whatsoever.
[/quote]
Ok thanks Ill check.One more question will my computer be ok with the bigger hydraulic flat tappet cam.I just dont want to tear it apart and never be able to get it to run right.Thanks,Kevin
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
[/quote]
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
ORIGINAL: myshifter
ORIGINAL: kevinek
[/quote]I am not the efi guru thats a given, Im almost postitive those SD cars work ok up to a certain point. my partner joel5.0 should chime in.
