Jumped to 24lb injectors in my 88 5.0 runs rough
RE: Jumped to 24lb injectors in my 88 5.0 runs rough
ORIGINAL: duslep
Silver 91, what upgrades do you have?
speed density computers have programmed fuel tables that are made for the stock engine, if you make it breathe better then it will run lean because it cant see the changes you make.
mass air computers measure the air your engine takes in and changes those fuel tables based on running conditions.
ORIGINAL: hotstang_88
No cats, H Pipe, 40 series Flowmasters, K&N kit, and 3.55 posi
the stock injectors are good until around the 300rwhp mark.
you probably have 190-200rwhp
ORIGINAL: silver91gt
you will have to get a chip burned if you change to different injectors on a speed density stang.
it wont run right with 24# injectors because it is still sending the same pulsewidths for the 19# injectors.
it is spraying way too much fuel.
musnicki
09-23-2015 07:11 AM
