Fram filters
#22
RE: Fram filters
ORIGINAL: 95hooptey
5liter............youve been to Mexico!!!
I have too! Wow, its amazing what someone can do with round objects!
nah man but i have seen a donkey show. its almost amazing what those girls can do with a freakin donkey..
#23
RE: Fram filters
ORIGINAL: Bad Karma
This wouldn't be from a problem with your filter, but a problem with your pressure relief valve in your oil filter spindle assembly on your engine. It's probably stuck closed and there isn't hardly any oil even going through your filter....happens in alot of cars with higher mileage or if you overextend your drain intervals..I used to see it once or twice a week - back when I had a JOB!
Unemployement RULES!!!!
Your friendly nieghborhood Spiderman,
Ivan
ORIGINAL: vristang
Check out the following link for a more technical discussion of oil filters.
Oil Filter Study
Another page of the same site has some conclusions.
Conclusions Page
The main problem I have had with Fram is that the filter is dry nearly every time I remove one.
This means that all the oil has drained out of the passages, back to the pan.
Each startup has to re-fill the oil passages, due to a poor anti drain-back valve.
I have noticed that I have slightly higher oil pressure with the Mobil filter as opposed to the K&N. The difference is about 5psi.
This indicates that the K&N may have a better filtering capability. There is usually a direct relationship between pressure reduction and filtering ability.
jason
Oil Filter Study
Conclusions Page
jason
Ivan
I have not had the issue since switching to K&N/Mobil filters.
jason
