egr coolant lines
RE: egr coolant lines
People do the bypass all the time on older chevys. What it's supposed to do from what I can gather is help the engine warm up quicker by circulating the coolant through the hot maifold, doesn't really need cooling much. Never heard anything bad about it plus you should be able to pick up a litte. When i can find the right fittings I was planning on doing it.
I have a 88 gt with maf conversion and my cr runs rich and lean. lean at idle and rich at wot. I have the egr coolant lines bypassed but the vaccum is still connected. Would this have anything to do with the rich/lean problem? If so should i just reconnect the coolant lines? thnx
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
