42lb injectors
RE: 42lb injectors
wideband in an electronic fuel to air ration monitoring system, it allows you to electroincally control how lean or rich the car (EFI) is running and tells you were to make adjustments
RE: 42lb injectors
because the #42 can handle the fuel supply w/ out it
wide band sensor----------> http://www.megasquirt.info/PWC/LSU4.htm
