Cam Help!!
Old 07-16-2006, 02:06 PM
hayden
hayden's Avatar
Default Cam Help!!
Hey guys, I'm thinking about putting a new cam in my car ('93 LX 5.0 h.o), but I don't really know which one to go with. I see how a lot of guys are using the "E-303" cams in their 5.0 stangs and I was just wondering if that would be a good one to go with for street use, and if so, about how much hp would I gain? and would it be worth the money spent? Thanks
hayden is offline
Old 07-16-2006, 02:59 PM
OneFine89Mustang
OneFine89Mustang's Avatar
Default RE: Cam Help!!
ford racing b cam ...is what most people use i went with the trickflow stage 1 cam and like it alot it is very choppy at idle
OneFine89Mustang is offline
Old 07-16-2006, 03:43 PM
hayden
hayden's Avatar
Alright thanks, but by choppy do you mean like rough?... because i was hoping to get one with fairly decent idle quality. And with that one how much hp did you pick up? and around how much does it cost? Thanks again for the help.
hayden is offline
Old 07-16-2006, 07:09 PM
Billymac76
Billymac76's Avatar
he's right about the racing b cam but you should probably go E303 that cam will give you gains and is also 50 state legal....
Billymac76 is offline
Old 07-16-2006, 07:20 PM
silver91gt
silver91gt's Avatar
depends on your setup.
silver91gt is offline
Old 07-19-2006, 11:10 AM
hayden
hayden's Avatar
well right now all it has is a K&N cold air intake and MAC exhaust
hayden is offline
Old 07-19-2006, 11:56 AM
Dath
Dath's Avatar
Cam is going to be around $200 and another $100 in gaskets, plus 8-12hrs of labor (depending on experience). You sure a new cam is your next logical mod?
Dath is offline
Old 07-19-2006, 01:38 PM
1BADASSLX
1BADASSLX's Avatar
i have the b-303 cam and it realy didnt show any horse gain till i put a decent set of heads on the car then it realy woke it up sound to
1BADASSLX is offline
Old 07-19-2006, 02:31 PM
hellas85stang
hellas85stang's Avatar
most cams of decent size dont have much gains unless intake is changed...usually a intake nd cam and cold air induction is worth around 20-40 hp
on avg..there sre exceptions..
hellas85stang is offline
Old 07-19-2006, 02:40 PM
gspfunk
gspfunk's Avatar
The cam is not worth changing as long as your heads are still bone stock. Get some different heads and an intake and put some 1.7's on it. The heads are restrictive enough that you won't notice too big of a difference by changing the cam.
Try getting a different intake and a larger MAF first. You'll notice bigger gains from those.
gspfunk is offline
Quick Reply: Cam Help!!
