Calling Balljoint Experts..
RE: Calling Balljoint Experts..
ORIGINAL: primetime5.0
actually i have replaced the front springs and i didnt use a compressor
how did you get them back in?
I struggled with a prybar and couldnt even get it to sit in the perch.
I removed everything and let the a arm free, put the spring back in and jacked it back up and connected everything
..just when u go to remove ur ball joints put the jhack under the spring and compress it. Then use the ball joint separator to separate the top ball joint and then just lower the jack and let ur spring fall out. Then remove ur bottom ball joint and then reinstall.
ORIGINAL: gsxrstang69
i did the same
there is no top balljoint, mabye you meant tie rod end?
