centrifugal supercharger
i am new to the carburated 302 world and have a few questions, i am sure that a couple of the questions have been asked befor. so if they have i am sorry.
question 1 with a centrifugal supercharger is it better to have the carburator feed the supercharger or to have the supercharger feed the carburator on the intake mani?
question 2 will the supercharger bracket be the same from a 85 302 and a 86 302, the reason i ask that is because i see alot of supercharger kits that fit the years 86 through 93 and they are only $1700 and the ones for 85 are $4200. i am just wondering if the bracket and supercharger will fit, the rest i can make.
thanks matt
thanks matt
RE: centrifugal supercharger
Q1: you always blow into the carb using an s/c box that surrounds the carb.
Q2: the 86-93 ones are so much cheaper cause they're fuel injection and
dont require a carb box for the s/c to blow into. It's not the brackets. A 302
block is a 302 block everything bolts in the same place.
Trying to put a centrif s/c on a carb is rather expensive vs. an EFI set-up.
you could always get a wiring harness and computer and intake manifold and injectors and fuel pump ........ lol
off ebay and switch to EFI, lol
you might look into a MadMax stlye roots blower, but you're not saving any money there either.
ORIGINAL: myshifter
if you have an 85 dont even think about switching it to efi, the gods will strike you down If you run the blower, just use a bonnet and blow through carb, the carb boxes are horrific.
if you buy the cheaper kit youll have to get a custom pipe to go to the car from the sc and buy a blow through carb but other then that you should be good to go. id have it dyno tuned if i was you
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
