WHAT INJECTORS AND ROCKERS 2 USE
i got a couple ?s im about 2 install my new motor its a stock 5.0 block with a trickflow cam(221/225 dur,499/510 lift)trickflow heads(1.46 springs,61cc comb cham.,170cc/66cc in/ex.runners,2.02/1.60 in/ex valve,600 max valve lift),performer rpm intake,pullys,cai,long tubes,msd,flows.what rockers and injectors should i use i was thanking 1.7s and 24s what do u all thank[sm=goodidea.gif][sm=badidea.gif]
RE: WHAT INJECTORS AND ROCKERS 2 USE
I would use any style 3/8" 1.7 ratio roller rocker, That will bump your lift up to 530/541. Stock pistons are good up to .550 lift before you have to notch them. I would also go with 24lb injectors with around 45-50 psi fuel pressure.
