another dumb question o' the day
RE: another dumb question o' the day
one is compression the other is rebound. not sure which is which, I believe it's the resistance to compression (when the wheel is going closer to the fender), and rebound (when the wheel is going further away from the fender)
From the total resistance of the shock piston to travel inside its cylinder...the percentage applied on either stroke (compression/extension)...a 50/50 is a "balanced" shock, same resistance in each direction.... a 90/10 has a 90% higher resistance to compress and 10% resistance to extend....they are used for drag racing in the front struts to allow a quicker weight transfer to the rear wheels....and if you do a wheels up start (yeah right)....you have a stronger resistance in the compression stroke, to dampen the fall of the front end.....Check http://www.competitionengineering.co...?CatCode=10333
okay, so for struts 90/10, and it means that they spring backand they decompresses faster to put force on the the rear (to pop some wheelies all day!!) and 50/50 would be good for rear shocks then?
09-02-2015 08:40 PM
