is this possible?
is this possible?
just out of curiosity... can a starter that gets unneeded heat cause an idling problem? for example, my starter needs a heat shield b/c my headers r causing too much heat to the starter, when my car starts up the idle is perfect, after a while tho the car begins to idle to the point of stalling, i no it could be a number of problems, but has any1 ever heard of an idle problem due to an overheated starter? thanks
RE: is this possible?
the starter does not make the car idle, the starter is for the sole purpose of starting. try this for idle problems.
http://www.muscularmustangs.com/maintain.php
ORIGINAL: ckyguy68
get a 190 lph fuel pump and your problems will be solved. i had that same problem only when it was hot and humid and my car would stall and not start for a few minutes then i could start it again and it would die again then i put a 190 fuel pump in and i havent had problem since and thats been 3yrs, trust me i was told it was all these other things but it came down to being my fuel pump
