FMU-Replace/Bad??
RE: FMU-Replace/Bad??
you never said what mods you have and more important what psi your using.....when your at the 42's is when things really need loking at as far as the 'puter just change the 'pham for now..before you waste your money on a dyno tune
I'm dyno tuning today with a 5 psi SC, 30 lb. inj, 73 MM MAF with the correct sampling tube, 70 MM TB and the appropriate FMU disk for 30 lb. inj. and a 190 lph FP.
I was told this is a good idea and the only way I'll maximize the set up I have.
