Alternator or battery?
Old 07-19-2006, 07:35 PM
Twisted
Twisted's Avatar
Default Alternator or battery?
So, recently I've noticed that my volt guage has been reading lower than usual. I put a meter on the battery today, and the voltage fluctuated between 12.55 and 12.60 volts. It should go up past 14 volts when revving, correct? Oddly, the higher I revved the motor, the lower the voltage went. Do you think it's my battery or my alternator that is bad?
It seems like the alternator to me. What is a normal price to pay for an oem alternator?
Twisted is offline
Old 07-19-2006, 07:36 PM
I3atR!ce
I3atR!ce's Avatar
Default RE: Alternator or battery?
if you want... you can take your alt to a place like autozone and have them test it for you, then you can rule that out.
I3atR!ce is offline
Old 07-19-2006, 07:38 PM
Twisted
Twisted's Avatar
ORIGINAL: I3atR!ce
I think I'll do that. Just trying to get an idea of what to expect. Thanks for the reply.
Twisted is offline
randy78045
randy78045's Avatar
ORIGINAL: I3atR!ce
i believe the can test the battery with a load as well... an i dont think ya have to take the alt or battery out for their diagnostics...
randy78045 is offline
Old 07-19-2006, 07:39 PM
sc94gt
sc94gt's Avatar
Could be the voltage regulator on the backside of the alt.
sc94gt is offline
Old 07-19-2006, 07:48 PM
lookinforastang
I ♥ Acer
lookinforastang's Avatar
pretty sure u can get a OEM alt cheap with a core charge
or u can just upgrade to a 160 alt should be around $150
lookinforastang is offline
Old 07-19-2006, 07:55 PM
gspfunk
gspfunk's Avatar
Start the car and disconnect the battery while it's runnig. If it dies or tries to, your alt is bad.
gspfunk is offline
Old 07-19-2006, 08:01 PM
89GTRed
89GTRed's Avatar
+1 they look MUCH better than stock and you will be well off if you ever get underdrive pulleys or a good sound system or whatever electric stresses you may put on it.
89GTRed is offline
Old 07-19-2006, 08:36 PM
WHITESTALLION84
WHITESTALLION84's Avatar
DO U HAVE A SYSTEM ON YOUR CAR....CAUSE THATS THE SAME THING THAT STARTED HAPPENING TO ME WHEN I GOT MY SYSTEM...I FIRST REPLACED THE BATTERY CAUSE THEY TOLD ME THE ALTERNATOR WAS GOOD...THAN THE ALTERNATOR WENT OUT THAN I REPLACED THAT...BUT I STILL HAVE A PROBLEM WITH MY VOLTAGE SO I JUST TURN UP MY SYSTEM TOO MUCH...I GOT THE OEM ALTERNATOR WHICH I REGRET.
WHITESTALLION84 is offline
Old 07-19-2006, 08:40 PM
Twisted
Twisted's Avatar
Thanks for the replies everyone. I'm getting ready to go to my mechanic to have the system tested. I don't have a high powered stereo system, or anything else that would put excess strain on the system. I guess the alt is just tired...at 110k miles. I just hope I can afford to get it fixed after having spent all my money on my new clutch.
Twisted is offline
Quick Reply: Alternator or battery?
