'94/'95 tail lights. about to paint mine???
RE: '94/'95 tail lights. about to paint mine???
I used semi-gloss when I did the 87 tails for my 86. I sanded, but didn't primer. I think gloss and flat don't look right. I was going to the 'covers' look. Just my 2 cents...
cheers
cheers
wash with a good soap, wipe down with silicone wax and grease remover, sand with some 400 grit paper wipe down with wax and grease remover again. tack them off , paint!
ORIGINAL: 89GTRed
but its not trim its the tail lights usually they are painted to match the car color i just painted mine black cause the car is red taillights are red and lenses are red. wanted it to stand out.
i didnt use primer for mine i just painted it right on the plastic since it was plastic paint... havent had any problems so far and i did it about 6 mos ago.
+1 for semi-gloss ... trim on cars, mirrors, grills, etc. you should use a semi-gloss trim paint. looks very oem.
well .. to each his own i guess ... but i don't know if you've noticed on a lot of vehicles, the factory mostly uses semi-gloss around the tail light area. be it trim, bezels, or whatever. from a design aspect you need to have some areas that are not glossy. i know a lot of guys paint their window trims, mirrors, and cowl grills with glossy black ... but IMO i think it looks like poo. i'm standing by the semi-gloss and all the others above me that have mentioned it, but again .. to each his own.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
