Everyone with bbk equals!!! help
I finally got my headers in today (bbk equal length shorties) and the stearing shaft rubs on one of the pipes.... it makes it harder to turn the wheel and will probably rub a hole in the header eventually?
did anyone else have this problem? anyone have any ideas??
RE: Everyone with bbk equals!!! help
ORIGINAL: Valcore
thanks..... but wait couldn't jacking up the engine hurt the rear seal? or anything else
ORIGINAL: aabensonae
While you are at it you should replace the engine mounts, that is probably what is causing the headers to hit.
i put bbk equal length ceramic coated headers in last fal and had no clearance issues, and the motor mounts are in mint condition, that may be the culprit... god luck and good choice on the headers
