Anyone Insatll A Flex-a-lite Black Magic
Has anyone installed one of these fans on a 93 GT Vert? Where do you put the over flow tank? Do I have to remove hoses? One off topic question, my over flow tank has a cap that does not stay on, but has plug onit. Can I get a cap that does not have that, or will it not work?
Flex-a-lite Black Magic Xtreme Series Electric Fans
RE: Anyone Insatll A Flex-a-lite Black Magic
Who needs one? Well if you ever hit the track you will, otherwise your gonna get harassed or might not even pass tech cause you might **** water all over the track if you overheat.
i dont use mine either, but im sure you could mount it in the stock position. just move the fan over to the passenger side of the car, and mount the tank to the right.
i have installed mine and even installed the over flow. But i just removed mine too. Went to Checker and bought about 2 feet of vacuum hose and just ran the overflow to the bottom.
they system comes with a bracket so the tank mounts in the stock location. every easy install (tank has 2 bolts it it and 2 bolts to the rad.) fan has 2 bolt on top and 2 on btm that clamp the radiator.
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
