So I'm the only one...
...that sometimes gets locked out of first gear? I asked this question a while ago, but got few replies. Every so ofter, I'll go to put it into first, and it won't go all the way in. It feels like shift dogs not lining up or something. Then, I let out the clutch, press it back in, and it falls right into gear like butter. Anyone else get this?
It just occured to me: Do car gears even have engagement dogs on them?
RE: So I'm the only one...
ORIGINAL: Grn N Gry 5OH
hows your clutch cable ? got an adjuster on it ?? anything like that........
By the way, I have no adjuster on my clutch cable. The stock auto-adjust feature seems to work well.
ORIGINAL: mrbigshot
its a somewhat common problem with t5's. ive learnerd over the years ti put it in reverse than 1st
dont have this problem w/ first.. but i have it w/ reverse.. hah if i adjusted my clutch (i have an adjuster now) and fairly new clutch could i fix this? or can i make it catch lower? cuz it catches kinda high. and the other day i went to down shift into 4th on the highway... and i wouldnt le me in it just made a grindion noise and i let the clutch up and it went in fine.. thats the first time it ever happened. so would adjusting my clutch do n e thing and what does adjustin the clutch do? sry i dont kno much about clutches
My car does the same exact thing if I try to go right into first. Usually when I first get in the car and go I'll put it in second then it'll slide right into first gear....freakin weird.[&:]
